Before I reques this, I just want to confirm two things
- There is no keyboard shortcut to implement a template, that is done through the ‘\’ command.
- The title is not replaced with the template invocation using the ‘\’ command.
If both of those are true, I would like to request both. #2 would make #1 more bearable. I like being able to title my notes a certain way, or when I invoke a template, I want it titled a certain way.
The \
shortcut is indeed the way to insert the content of a template into another note. If however you want to have a new note created from a template, where also the title of the note is taken from the template, you can do so by click/tap-and-hold the plus button at the top of the screen.
That’s what I figured, and the behavior I’m seeing.
This is more of a convenience thing. I can navigate just about everywhere in the app with the keyboard, except creating a templated note using a titling scheme.
I see, I’ll see if I can extend the \new
action to be able to take a template parameter, something like: \new(using: Book Review)
Update: I’ve just added this to the next update.
