When I split my screen, the Agenda window still doesn’t reformat properly. I end up only seeing part of the Agenda window. Are there any further updates planned to change this?
Thanks a lot,
Carolina
Thanks a lot,
Carolina
Can you send us a series of screenshots of what you describe?
Also, can you show how you exactly invoke split screen?
Sorry for the late reply, I only just saw your message.
I use split screen a lot when I join a Zoom meeting using screen share. However, I just carried out the newest Agenda update and it seems to be working fine now. Therefore at the moment, I can’t share any screenshots, because the issue seems to be fixed
Ah glad it was that, we indeed fixed that a few updates ago. btw I think you’re going to be very happy with the upcoming Agenda 17 update if you use it often in split screen in combination with zoom for example
