My preference is to use Agenda in Dark Mode, but the issue I’m having is that the red underline that shows up under mis-spelled words is not showing up or is not visible.
Is there anything I can do to either activate the function or change the colour of the underline so that I can see mis-spellings more easily?
Thanks,
Is this issue persisting also after quitting and restarting Agenda?
Note that spelling only shows when you are editing a note. So you have to put the cursor in the note to see it. Is it still a problem even with the cursor in the note?
Also, is spell check turned on in Edit > Spelling when you have the cursor in a note?
Ah ok - so I have to hold my hands up and say that I didn’t realise I needed to turn the spelling functionality on.
That seems to have fixed it though.
Thanks for the help - apologies for the post!
