Can you consider adding the ability to check spelling when in preformatted style, since it’s the only way to write in plain text within the system.
Are you planning to introduce a plain text feature in the system?
Thank you
Thank you
I’m afraid we don’t have any plans for a plain text feature at this point, no.
The reason we disable spelling in preformatted blocks is that it is often used for programming code and other stuff that doesn’t work well with spell checking. We will keep your request in mind, but you may be better just getting used to using the standard body style.
