Hi guys, Is there some way I can assign one (or more) specific calendar(s) to a specific project and not have any of the others show up? I use Agenda as an organisational tool both at home and work and would like to be able to have a project default to a particular calendar - so I don’t have to constantly keep checking which calendar I’m on.
Thanks in advance!
This isn’t possible at the moment but has been requested a few times indeed, we’ll think about it.
Thank you!
And thanks for all your work on this amazing app!
Yeah, this is an obvious need. Ditto regarding Reminders.
I’d suggest that calendar sets and list sets would be a useful way to satisfy this request. I have several projects that would use the same set of calendars and lists, so rather than configure each project, I would want to define a named set of calendars and lists, then assign that set to a project.
