Hi - I would find it very helpful if it were possible to automatically move completed (ticked) Notes within a Project to the bottom of the Project list. I have some Projects with 20+ Notes and it would be helpful to see more easily which have been dealt with and which have not. Is that possible now, or planned for the future? Thanks
We’ll keep it in mind. Note that you can mark notes as “Footnotes”. This pins them to the bottom. Perhaps that is a workaround for you.
How about holding down the option key while selecting ‘make footnote’ also collapsed the note? I tend to use footnotes for stuff that needs to stay with the project, but I rarely need, and collapsing them keeps things tidier!
Not sure it warrants a separate shortcut. It’s pretty easy to select a few notes and collapse them. But we’ll take it in on board. Thanks!
