Sorting notes with same date
How are notes with the same date sorted? I have two notes with the same date that I would like to be in a specific order, but if I try to move them, it says the date will be removed.
Normally it should be no problem if the date is exactly the same, i.e. the same day. However if one is linked to an event and another to either a different event or whole day, then you can’t reorder as there is a fixed order. Also, if one is assigned to today, and the other to say today+tomorrow, you will not be able to reorder them. Is any of these the case?
Ah, I see. Yes, one is linked to an event and another to a whole day.
