At the moment, if you try to create a link (by using the “short cut” [[), and it so happens that you have notes that are named the same (which I have lots of), then notes are sorted by assigned date going from oldest to newest. I think that is seldom what you want. It would be better if the order notes in the link popup appaer in would be from newest to oldest, not the other way around.
We’ll take a look to see if indeed this needs changing.
too many lists in agenda don’t have option for sorting - open quickly same problem forcing oldest to newest sort - newest is way down long list
