Smoother scrolling
Having played with Agenda for a while, I notice that scrolling (on a MacBook Pro, in my case) is still a little jerky when you scroll down a list of notes. I suggest fixing this should take fairly high priority – it’s something that could grow quite irritating over time, especially as lists get longer and longer.
Thanks Bill. Indeed, there are some performance wins we can make, and plan to during beta.
Outstanding! Thanks.
Today’s c3 update should improve scrolling performance significantly, please let us know if you notice an improvement and how you rate performance after this update. You can update the app using Check for Updates under the Agenda menu. Many thanks for your feedback!
