What I did: I am trying to create a Smart List fust from a Tag, Star or something that will provide the line item from the particular note into a list.
What happened: When I use #tag, I receive the entire note that includes the tag.
What I expected: I wanted to particular item that was tagged to be presented in a smart list. If I wanted to get back to the note, then I could use the hyperlink.
This is indeed something that is missing and among the top items on our list to work in the series of updates to come.
Thank you for letting me know. It would be great if this feature could be evolved so that you could use a feature that puts items into a list? I would suggest that it be similar to tagging. For example, if I could indicate open questions, note to self or action items which then I could automatically assemble a list based on the codes which in this case would be 3 mutually exclusive lists.
Thank you for the consideration.
Darren
Thanks for the suggestion, we’ll take it on board!
