I like the way you can use the small orange dots to the left of text to change formatting etc. It would be good if these were slightly larger and could be grabbed and moved, or, just like in Apple Reminders, the item/text to be grabbed and moved up or down. This would
be especially helpful on tablets and phones.
Thanks for the feedback! Indeed that is on our todo list. Taking it along for future updates.
Disregard if you’re already aware. You can currently drag the formatting pop-up where you want after opening. Once moved you can continue to edit what you choose w/o using the dot. The next dot you press will close the pop-up. (most of the time)
