Often I just want to quickly jump back today on the timeline pane e.g. I really like how Fantastical allows us to click the month/date to focus on/jump back to today and would really like to see some semblance of that in Agenda.
Also, I noticed that the pop out widget (UI calendar and jumplist) on clicking the timeline calendar icon doesn’t consistently place the widget depending on the window location on the screen and messes with muscle memory – screenshots below.
Suggestions:
double click timeline calendar icon to jump to today
consistent location of UI calendar/jumplist on clicking calendar icon, preferably the latter
center aligned when agenda window doesn’t reach the top of the screen:
top aligned when agenda window reaches top of the screen/maximized:
If you scroll far enough that the current date is no longer in view, Agenda places a little circle to the right of the calendar icon and month indicator. Press that circle, and it will jump back to today:
Thanks for the feedback, unfortunately the positioning of the sheet is done by the system and we can’t control it at the level you suggest. Having said that, in the next update we have some significant improvements to keyboard navigation of these views, which means you don’t even need to touch the mouse if you want.
I’ve just noticed that on the iPad the ‘go to today’ circle is always present, but in Mac I have to click where I think it should be, and on the iPhone it doesn’t seem to appear at all.
