- in a note of unformatted paragraphs, put the cursor within a paragraph
- open the gutter formatting menu
- select eg the “preformatted” paragraph format (but it works for any paragraph format)
- keeping the formatting menu opened, hit backspace, then return
- the current paragraph has lost its formatting, but the formatting menu still shows it as “preformatted”
- to actually apply the format to the paragraph you need to hit the preformatted icon twice
MacOS 11.4, Agenda Version 13.1.1 (195)
