I created a checklist like you see on the attached pic.
I selected all, then „Sort Checked to Bottom“. Result is what you see on the picture. I expected to see „Ø bbb" (incl. „- ccc") at the bottom of the list because it is checked.
I see. Will try to fix. Thanks!
Ah very interesting. Is this feature only available in macOS? Can’t seem to find it on my iPad.
Yes, just macOS at this point.
I’ve fixed this. Will be in the next minor update.
I tested it in beta 10.0.3 and it is fixed! Takk, @drewmccormack!
Good to hear!
