- The color of the sidebar is too bright when in dark mode.
- The short cut function on command+1 work well at first, but it will not work after that. For example, pressing the ‘command+1’ key first, then the ‘command+2’ key will not work.
Many thanks for the feedback and the issue report with the shortcut, we’ll investigate the latter.
