This is a little different than the reminders integration.
It will create a reminder from the selected note
- The title of the reminder will be the title of the note
- If there is a list in reminders that matches the project name it will be put in that list
- The due date will be the date of the note
- If the note spans multiple days it will use the end date
- If the time between the date and end date is less than 3 hours, it will use the start date. (I wanted it this way for meetings)
- It will add a link to the note in the description
https://www.icloud.com/shortcuts/76968ed475ac4a8c8cc16bde53a53662
Lori
Edited to update the link.
