Shortcut for Collapsing Notes Doesn’t work consistently. Is anyone else experiencing this. It works sometimes but mostly not.
Actually, discovered that you have to be clicked inside of the title region for it to work. As long as I do this it works consistently. What’s confusing about that is that the menu item works regardless of whether you’re in the title area or the main body area.
Glad you found it, indeed tapping outside the title region is reserved for highlighting the note etc. otherwise it would affect the normal text editing behaviours.
