What happened: There aren’t any options of where to share the link. The link went to the first Project I created.
What I expected: I was expecting the process to work as it does in Notes where a dialogue box pops up and there are choices of where to put the link and add text to the process.
Agenda 14.0.4
OS 10:15:7
Thanks for the super clear video, the jumping is indeed a bug, hadn’t noticed it being so bad, possibly related to being on 10.15, we’ll dive into that.
Regarding choosing a different note, you can do this by simply clicking the project of the note at the top, it will then present you with a menu from which you can choose any other project/note in your library:
