What I did: I wrote meeting minutes, referenced a website, and pasted two images into the note. I hit the gear in lower right, share, save to files, save to acrobat reader, and save to notability
What happened: save to files popped up a blank white dialog which then closed on its own; save to acrobat reader did nothing; save to notability threw an error dialog:
What I expected: Notes to be stored on files as a pdf, notes to open in acrobat reader, note to be copied to Notability
Things that might be helpful to know (Agenda version, OS and model, etc): Agenda 4.0, IPad Pro 2018; iOS 12.1
I just tried exporting notes with attachments to files using PDF, and it worked without issue.
Does it fail for all notes, or just a particular note? If it is just one particular note, any chance of exporting that as Agenda file and sending it to me (drew@agenda.com)?
In each case I was able to share to Notability as one would expect.
I am not sure what happened to that one note, but I will say it is the first where I tried any of that, and it may be that in the couple of tries it took me to create the link to ‘The Teeneage Brain’, I might have created some corruption. It took a couple of passes and that functionality is ‘active’ within the note in order to convert that format into a usable link. I would look there to see if there are any ghosts gumming up the works.
Not sure what you can see within the file beyond what I can see.
At any rate, since it isn’t coming back as an error, I am satisfied.
