Settings > Calendars display
What I did: open settings > calendar. Try to select calendars to show
What happened: dark background with dark text = can not read the names
I have a screenshot if that is helpful.
iPad M4 OS 18.1.1, Agenda 19
Sounds like a glitch. Does it help to restart the app?
It does not. Glitch is still there…
Note: my iPad is set to dark mode but I have Agenda set to light mode. Possible confusion there?
Hmm, most likely the reason. I guess if you change one of the settings, it does work, right? What if you switch it, and then switch it back? Does that fix it?
BTW Did you try the new Agenda 20 yet? Does that fix it? It is out now.
After switching Agenda to either of the Dark Appearances (Dark or Black) the Calendars names are visible. Switching Agenda back to Light Appearance brings back the glitch: Black Calendars window with (apparently) black text; i.e., no calendar names visible.
Agenda 20 has the same issue for me.
This happens on an iPad M4 with iPadOS 18.1.1 and on an iPhone12 Pro with iOS 18.1.1. On my Mac the issue does not occur.
OK, thank you! We will look into this.
