Setting consistency
Hi Alex and Drew,
It would be nice that some settings are set the same across all the devices running Agenda. One simple example is unordered lists: dashed or bulleted.
Once you change a setting on one device, it propagates to all other ones.
I have several devices (some are personal, others are BYODs enrolled with Microsoft Company Portal for specific security policies). Agenda runs on all of them.
Thank you.
Florian
Indeed for some prefs this makes sense indeed. It’s a bit tricky because we need to create a way to store them inside the settings. For just this particular use case it doesn’t warrant the work that is needed, but if we need this as part of a bigger update down the line we can include this with it.
