Send to Agenda
Just found out about and tried this feature. Nice feature but cannot get \move command to work - only puts note in inbox. Also not sure of correct spacing in \move command. What am I missing? Thanks!
Hi,
Glad you’re trying it out.
A couple of things on \move. First, the project name needs to be in quotes:
\move(“ProjectName”)
Without the quotes, it gets left in the note as plain text.
Second, we’re still ironing out text actions running automatically on inbox notes. A few like \move are working in the current build, others like \reminder still need work because they require UI. So if quoting the project doesn’t fix it for you, that’s something on our side to sort out, not a setup issue on your end. Let me know how you get on.
Good morning,
Thanks for the reply!
I’ve used the quote marks but have tried with and without any spaces after the word move. Nothing works. They all landed in the inbox without stripping out the command syntax.
Thank you
Bill Tyler
Hi Bill,
Thanks for trying again. Sorry to confirm it, but this is on our side.
Even with the correct \move(“ProjectName”) syntax, automatic text actions on inbox notes are still not running reliably in the current build. We have a fix in progress so that the actions get processed when the note lands in the Inbox. Until that ships, your notes will keep landing in the Inbox with the command text in place.
The workaround for now is to open the note in the Inbox and let the text action run there, or move it manually.
The fix will be in version 23.1 coming in a few days.
Thank you for developing this premium feature. It is a very helpful app, and I look forward to seeing added functionality, such as \ota and \assign-date().
Thanks! You can actually already use \assign-date. Put it in the body of the email, eg \assign-date(friday). A lot of the other text actions work there too, though not all of them. There is also \on-the-agenda
I followed the steps, as illustrated in the screenshot. When the email is sent over to Agenda, two syntax \on-the-agenda and \assign-date(friday) are showing as text rather than action. I want it to show “On the Agenda” and with date assigned.
Thanks for the screenshots, that is clear. The \move and the tag came through, but \on-the-agenda and \assign-date(friday) stayed as plain text. I’ll look into why.
Found it and fixed it. \on-the-agenda and \assign-date(…) in the body of the email will work in the next update, along with \done, \pin and the day actions like \friday. Keep them in the body, not the subject.
Thanks for the clear screenshots!
