I understand from other threads that there are plans to make it possible to work on one note while viewing others. This will take Agenda up a whole level for me, helping me use a Agenda as a thinking tool.
But… on Mac, please allow the option of opening two windows, to make use of dual monitors.
While a third column type solution would be an improvement on the status quo, two windows on dual monitors would be much more flexible.
We’ll consider it, but I think our focus initially will be to split off a note from the main window. That will be a second window, but not a full main window copy, if that makes sense.
Hi @drewmccormack - that sounds good! I’m not looking for a duplicate main window, ’simply’ the ability to have two windows. If one is the current standard window, and the second is window displaying a separate note, that would be great.
The main thing to to be able to drag the two windows to different monitiors.
We don’t give dates, because they simply are not known at this point. It is complex to predict, and other higher priority projects can cause things to be delayed. This is one of our top priorities though, so we will get to it sooner rather than later.
So glad to hear this one is a top priority. I’ve seen so many people asking for it. I think it will be a big hit. Thank you guys for all the innovation. I am in Agenda every day!
Still can’t wait for this. We keep trying to refer to one note while working on another. We have workarounds but sheesh this is a daily need. Love Agenda … make it stronger!
