Hi, is there a quick way to find a project or sub-category in the Move to … area? I have many projects and categories and moving something from the general inbox is a nightmare. could you add a SEARCH field at the top?
Thanks, Dirk
It should already work if you simply start typing to filter, a search field will then appear. Alternatively you can type \move in the text of the note and use the autocompletion system.
