It’d be nice to be able to right-click and make a note scrollable in case the note is super long and you’d like to still be able to see the next one. Hm… how to handle a ‘default length’? Maybe allow for storing in preferences? Or just force a default?
Not exactly what you mean, you want to turn it into a fixed height where the note itself can be scrolled down? Interesting idea.
+1 for an “option” to use fixed height for notes by project. This way it could be toggled depending on current use for that project. The initial set number of lines would be visible so one can scan the open project with more detail than merely the note titles, but easily turn it off when it’s not needed.
