Occasionally my (scribble) notes disappear. More often than not, they reappear. But sometimes they are gone for good. I’ve only had this occur in Agenda although it certainly has improved in this area. Help.
I am using iPad app os 14.5 , I believe.
What type of scribble notes do you mean? Do you mean where you write on the note and it is turned into text? Or do you mean you insert an image and write text in that?
We did have issues in the past with inserted images. Best check you are completely up to date everywhere with your version of Agenda.
