Same note in two projects
Hi there! Is there a way to use the same note in 2 projects? I need to have some information in two projects so when I change that note in one project in the other project the note is automatically updated. If is not possible, do you recomend other ways to adress the issue? Thanks in advance!
This isn’t possible alas, there’s a strict 1:1 relationship at this moment. One solution is in the second project to have a note with a link to the note in the other project. You can create an Agenda link to a note on the Mac by used Edit > Copy as > Agenda Link) and on both Mac and iOS through the cog wheel button in the bottom right corner of a note.
That seems like a fair enough solution. Thank you very much!
