Hi there
Thanks for this impressive app!
Here my request:
If I export a note as RTF the title will not be exported. I would love to see the title not only to be set to „Untitled“.
Could you fix that?
Hi there
Here my request:
Could you fix that?
Are you referring to the filename? And can you indicate the exact steps you take to export?
Sorry for not having been specific enough.
I think the possibility to have strong export options is important for not feeling locked in. Moreover, there should be an option to export all notes inside a project in the form of many single files with one click.
Ok, that’s clear, we’ll have a look.
