I found the possibility to directly use the camera or import photos very important for meetings, but I wished the images could be resized after import. Would it be a lot to ask to do that? The reason is that I often export the notes to PDFs to share with collaborators, and the imported imaged create weird page breaks and stuff like that.
We don’t allow resizing at this point. The images try to fit the width, although there is a maximum height. Perhaps we can consider more control in future. It is complicated by the fact that the images have to work across many different devices with different screens, so a fixed size wouldn’t work great.
Have you tried using thumbnails instead? They probably won’t interrupt the flow as much.
One more suggestion: you can export in RTFD (Rich Text with Attachments). Perhaps you could open up the export in MS Word or a similar program, and “clean it up a bit” before printing. Agenda is focussed on making notes fast, and so doesn’t offer the same flexibility for text styling that word or pages does.
