Reset preferences
What I did: I make a mistake and deleted notes. I quit a notification that acuse when a note is deleted and ask for confirmation
What happened: I can’t take the note back
What I expected: Can I reset the preferences in order to Agenda ask me about note deleted confirmation ?
If the app is still running, you could bring back the note using undo. But perhaps it is too late for that.
If you have a time machine backup, you could go back to the data before the problem and get the note that way.
You can reset the preferences by removing the preferences file:
  1. Click on Finder
  2. Choose Go > Go to Folder
  3. Enter ~/Library/Containers/com.momenta.agenda.macos/Data/Library/Preferences
  4. Drag the file com.momenta.agenda.macos.plist to the Trash
  5. Restart your Mac
