@trebso and I had talked about having pop-up or some type notes for Agenda notes. I’ve been thinking of a way to show a more friendly version of the related panel and tried using a header.
So you want backlinks listed in the note? Is that it?
It’s a request we get occasionally. I think if we did this, it would be a more formal section of the note, rather than embedded in the content itself. We’ll give it some thought.
The post was simply sharing a way I thought of to keep small notes, citations, and links for the current note, that were not always visible in the main content. Collapsible headers placed at the bottom is currently the only way I can do that (it works rather well) and meet my criteria:
- As long as what you see is relevant to the current note
- Easily accessible from every note
- Easily read and doesn’t divert your attention
- Does not hide other data when open
Hey, if something could be a built in function of the notes that would be great. I’m 67 so I just do it.
I’m not talking about algorithms looking for fuzzy connections either. Just places for user created links to and from each note.
Ah, sorry. You sent to Feedback, so I figured it was asking for a feature. But seems you were sharing a system you developed, is that right?
Appreciate the ideas!
