Recycle Bin
I think it would be interesting to have a trash can where the notes were removed, at least for 30 days, or a configurable number of days, to be able to recover them during that time.
This is indeed something we have been discussing internally.
Did you put it in the roadmap?
+1
My task manager has that feature and it can be a real life saver.
Yes it is on our roadmap.
Hello,
I accidentally check the box to hide bin pop up warning.
A way to go back state like : reset all warnings ?
And curiously now I have to drop a note in the bin to delete it, no way to use the keyboard again or the option Move to bin
That sounds like unintentional, we’ll fix that.
You can reset the warning by quitting Agenda and entering the following in the Terminal.app:
defaults delete ~/Library/Containers/com.momenta.agenda.macos/Data/Library/Preferences/com.momenta.agenda.macos suppressDeleteSectionsAlert
Hello,
Done thanks ^^
