Recurring meeting -> Remember and default to previously used project for new note
I have recurring meetings and projects associated with those meetings where I repeatedly create and store notes that are linked to the repeat meetings. I spend a lot of time repeating steps that could be optimized by simply implementing a most recently used option for creating a note for a repeating meeting from the calendar event picker. Perhaps an additional option for “New Linked Note in Last Used Project” if the meeting has the same title as before?
Is there already a feature that essentially supports that type of workflow?
Are you using templates? What I would probably do is setup a note just like you want to start with, and save that as a template. Then, when you meeting is going to start, tap on the calendar event, and choose “New Note from Template…”.
In effect, you get the new note, linked to the event, in two clicks.
