Question about due dates
On one note, I set a due date of “#due(next week).” The problem is that it ALWAYS says next week, so I never really know when it is due … Is there any way it can show that it is overdue? Thanks!
I don’t think we support #due(next week) as a due tag with an associated concrete date at the moment, something we should probably add indeed. Problem to some extend is that it’s ambiguous what next week means, the monday of the coming week, or 7 days from now.
With that in mind I would suggest to use either #due(in 1 week) or #due(in 7 days), both will translate to concrete date. Note that the “in” part is optional, it will also work as #due(1 week). Hope that helps.
Yes that helps tremendously thank you!
