I want create a template project and then reuse it for creating new projects. Currently I don’t see any option to Copy Project. I get only “Edit Project/ Delete Project” on right click. Please consider adding this support.
Good idea! Thanks.
In the meantime, I think you can copy notes, so maybe that is a workaround.
