Is there a way to take an existing Project and change it into a note of another project? As I’ve use Agenda more, I’m looking to consolidate ideas.
You can move individual notes from on project to another, but you will have to do each individually. Just click on the gear icon in the lower left.
You can’t merge an entire project into another project en masse. I can see where that could be desirable.
You can drag notes into other projects by the top as well.
