I got the logs, but unfortunately couldn’t find anything directly responsible. There were a few errors in there I was able to fix, but I would be surprised if they were the cause. Possible though, I guess.
I found that changing to a completely different project, and back, could sometimes clear the issue. Does that work for you?
Hi Drew, it seems to be completely random as to which notes/categories get ‘stuck’, but I’ll start doing screengrabs at each occurrence to confirm. Will post if I see anything reproducible.
Changing/adding/deleting projects doesn’t clear anything unfortunately. Very strange
I may be premature here, but it looks like your latest 18.3.2 (295) release does indeed fix the issue for me!!! Knock all the woods!! It’s like a new app. I haven’t seen a recurance since the latest release, which is really saying something. Will certainly post if it recurs. Thanks Drew!!
A quick update to let you know that Drew has managed to find some ways to reproduce this now and we have a fix coming in our next release. Thank you so much for your help in this!
