I still have the problem that the sharing of documents, especially PDF files with “Agenda” sometimes doesn’t work.
It does not matter whether it is a large file with several MB or a small file with a few KB.
For example, I am trying to share a PDF file with “Agenda” from the “Yoink” app. I can create a new note in the Share menu. But if I want to insert the PDF file using the + button, the process abruptly aborts and I end up back where I should choose which app I want to share with.
I don’t have this problem when sharing these files with other apps. It is limited to “Agenda” only.
I wrote to support. I was told that it was due to the size of the PDF files. I can’t imagine that, though, because the files have different sizes and, as I said, work without any problems in other apps.
Does anyone else have this problem and can offer a workaround?
This problem occurs on iPhone 12 and iPhone X with latest iOS.
