- Opened Agenda in full-screen
- Created a note
- Clicked the icon
- Clicked “Choose Connections…”
The popup to choose the connection hides under the sharing popup
That the popup would not hide.
I’m using:
Agenda Version 18.3.2 (295) - (Test Flight, but I had the issue also in the Mac App store version)
macOS 14.4.1
Macbook Pro 16-inch, 2021
Oh, very odd. That should definitely not happen.
Does it happen every time you try this, with other notes too? Did it ever work for you before?
Does restarting the app help?
Was there anything else that might play a role in this? Eg. It looks like you are in dark mode, but the note looks white, which would be unusual.
Answering in order:
Yes
Yes
No, it does not. Same for restarting.
Nothing out of the ordinary. The note in the screenshot was gray because the text was selected.
Thanks for the info. I will add this to my list to check for Agenda 19. Sorry for the trouble.
I realize I somehow missed the “full screen” in the title. Does this only happen in full screen mode?
Yes, it works perfectly if not full screen.
OK, thanks! We’ll investigate this bug.
