When I create a note and link it to a past event in calendar, because I want to connect with a past meeting and in calendar are mentioned useful information, then I try to create an event to put this note in the calendar for one of the next days, the app crashes…!
Any suggestion on how to link multiple events up and down the calendar in the same note? Thanks
I’m not entirely sure I follow your description, could you illustrate it with screenshots?
Note that you can’t connect a single note to multiple events. Having said that, Agenda should never crash, did you submit the crashes under your name and are you using version 1.3?
I tried to do it again but Agenda did’t crash anymore. If it happens again to me, I let you know.
