I would like to be able to print a single note. Now it is printing all the notes under the same topic.
Did you try first selecting the note? Ie turning it yellow?
Right now there’s not a very easy way, the workaround is to search for the note (or set a date filter) such that it’s the only one visible, the print. We hope to make this easier in the future.
Any update on this? I’d also like to print a single note simply. Thanks.
There is a Print menu in the cog button at the bottom of the note. If you use that, it will just print that note.
That should have been obvious, but I missed it. Thanks for explaining!
Is there still a print option in each note’s cog (MacOS)? There’s a Share item (which is where print might appear on iOS), but I don’t see Print there.
In Agenda 14 print will be also there on macOS.
