Slack has two very useful keyboard shortcuts for quickly jumping backward and forward between conversations.
- Previous channel or DM visited: ⌘[
- Next channel or DM visited: ⌘]
I think Agenda would benefit from the same shortcuts to quickly jump between notes.
These shortcuts would clash with indentation while editing, but I can see the point, we’ll think about it
True. Though Tab and Shift-Tab currently have same effect and are, for me anyway, more familiar shortcuts for indent/unindent.
Note that we have a history feature, the two buttons at the bottom of the sidebar. You can also go back/forward using View > Back and View > Forward. Both have shortcuts. (You could customize those in System Preferences if you want to.)
