Well, I have wrote too much posts today because I have spent all the day playing with shortcuts and I go from no understanding callbacks to feel pretty comfortable.
Before anything: I have inspired the shortcut in one seen in this forum, but can’t remember the user, I would edit after check it.
Explanation: The original shortcut take rich text but I can’t figure it out so I use text, that also make it work with all types of content: articles, messages, etc.
The shortcut takes text. It makes the first line the title, and all the rest of the text to notes. Now it goes the tricky part.
I don’t know how to auto obtain or autoapend the note identifier so I have to copy the agenda link manually to the note (new or already created)
If the text include agenda:// It creates a reminder and as I use goodtask, it makes subtasks all the lines that start with -[ ] and completed if [x].
The rest of the text is added in reminder’s notes. And it obtains the agenda URL and insert it into the reminder.
Finally it append a goodtask callback to agenda that opens the task automatically.
I created a project called Listas for the imported texts, you can change in the URL step above the “if not”
It’s very powerful even for import stuff quickly. Take a look and let me feedback.
https://www.icloud.com/shortcuts/c2555dd390df4d58ad11704a87680796
