Possible to export or archive entire category?
Hi. Have a category with 20+ projects inside and would like to backup and delete from agenda. Is it possible to export or archive a category instead of 1 project at a time?
Unfortunately this isn’t possible at the moment, we’ll try to add more export options down the line. One “workaround” is to shift/command-select multiple projects at the same time in the source list and then export as an agenda file. That allows you to do it in one go, it will however result in a single file where upon import the project structure would be lost.
Thank you for tip. Pity structures would be lost though. Please do help add export of categories as feature request. Thank you.
Yes - count me in on this feature.
Me too, we need this please!
