What I did: Selected to pin a note to the top in On The Agenda
What happened: Moved up but then shot right back down to the bottom
What I expected: That it would stay pinned at the top of On the Agenda
Pinning only works at the level of a project, you can’t pin a note from a project that’s not at the top in an overview (like On the Agenda), it will in that case only get pinned and go to the top of its own project.
Ah. Thanks. Thought it would let me pin within the view I had open. Appreciate it.
