I just bought Agenda premium. I tried to pin a note on top of the project.
The option to pin a note is greyed out.
I will be able to pin the note on to of the project.
MacOS 10.15.7, Agenda 11.1 (151)
This is indeed a bug that will be resolved in the upcoming 11.2 update. In the mean time you can use the pin to top option in the main menu under the Note menu, or by clicking the orange dot next to the title.
Thanks! In meantime I found solution with Note menu, but I didn’t know about the dot.
