Hi,
Would it be possible to trigger a Shortcut for Agenda which opens a new note whenever a phone-call is ended? I looked in the Shortcut library but no such trigger seems to be available.
Is there a workaround?
Thanks,
Rob
Hi,
Thanks,
Rob
Not sure, I’m afraid this is really on Apple’s end as they’d need to provide the Shortcut. In the Automation part of the Shortcuts app you can trigger a shortcut to be run whenever you exit the Phone app, but I can imagine this would run it too often. Perhaps a good idea to leave a Feedback item with Apple to add the Automation option to trigger shortcuts after a call has ended.
Thanks.
Will do!
