Permission problems when exporting to Markdown
Selected a project, selected Share, selected Save As File, selected Markdown, selected “As separate files”
A macOS (13.4.1 (c) ) warning shows up:
You don’t have permission to save the file “My work logs” in the folder “Agenda Exports”.
To view or change permissions, select the item in the Finder and choose File > Get Info.
The folder “My work logs.md” was created, but there are files in it. “Get Info” shows that I can read and write here. I do not have problems to store files in any other app on this macbook.
files being in the folder
    macOS 13.4.1 (c) (22F770820d), Version 17.0.2 (271) - Mac App Store
BTW, exporting as a single file works as expected
Unfortunately this is a known issue caused by the sandbox Agenda is placed in, what usually works is to export to your downloads or desktop folder instead when you get this error.
I’m experiencing this same error. I’ve tried exporting to a bunch of different folders - downloads, desktop, directly to MacHD, Google Drive. Nothing works.
Yes, it’s very frustrating and something we still try to find a work around for. Does exporting to the Downloads folder work for you?
