Came across the odds:
pasting a markdown outline from another app onto the content of a similar Agenda note (selecting all note text and then paste)…
… Result: text is corrupted by all headers turned into tags using some beginning of the next word (not even the full word)
Workaround:
- erase content first then paste - no problem
- use empty note - also fine
While I don’t think this is an intended feature - maybe hint at a deeper problem …
maybe you could take a look at it
