Parts of agenda not turing black on Mac dark mode
turning on dark mode on macOS catalina
some parts of the app did not turn black, as depicted below
usually it’s the background of the center column where the notes reside that refused to turn black.
This issue resolves after the app was forced to shutdown and rebooted
dark mode without this bug
Macbook pro Retina 13’ mid 2015. running macOS Catalina 10.15.1
Agenda ver.9.0
Do you have the scrollers permanently shown?
Hi,
I think they are? it’s shown both in bright and dark mode. I wasn’t aware of them so i’m not sure whether there’s anything wrong about it?
here are some sample of the conditions
-> sometimes both the column and the note failed to turn black(the words inside seems to turned white and disappeared)
-> the “Today overview”, no scrollers in neither bright and dark mode
-> only the column failed to turn black
I think they are?
Right, yes, if you have the scrollers permanently shown this should now be fixed in the 9.1 update.
Hi, it worked beautifully. Many thanks!
